2005 4x4 rotor change
Discussion in 'Member Introductions' started by SCASECHEVY, Apr 25, 2010.
    SCASECHEVY New Member
    Question trying to remove the hub from spindel, have removed the bolts to the
    back of spindel, is there a snap ring under the speed sensor and is the hub pressed
    onto the spinel. Rigth now using slide hammer to remove hub but no luck
  2. 2COR517
    Did you pull the CV shaft?
    Yes , i started by rmoving the spindelas a unit, but put back on as i did not see how to
    support the spindel and press off hub.
  4. Eddie Z71
    Hi, and welcome to the site!:glasses:
