2005 Diff Fluid Replacement Question
Discussion in 'General Chevy & GM Tech Questions' started by justinw2116, Oct 4, 2010.
  1. justinw2116
    justinw2116 New Member
    I am a bit new to the GM Trucks, but I am pretty car savvy.
    As I have found, to replace the Diff fluid, on a 1500 2WD model; I have to spin the bolts off the diff cover then drain it. What fluids do you recommend to refill it with? And how much fluid do I fill it with? Any clue what the torque specs are for the diff cover bolts?
  2. silveradotrailblazer
    I use Mobil 1 75/90 synthetics, 2-3 qts. I also after old fluid is out spray the inside of the housing with brake clean to get all the old fluid out. I then spin the rear to check the ring&pinion teeth. If everything looks good put on a new diff.cover gasket and reinstall and fill.
    ---------- Post added at 12:24 PM ---------- Previous post was at 12:24 PM ----------
    Also welcome to the club.
    x2....On what Silveradotrailblazer has mentioned.
