2005 GMC Yukon XL Driver's Side Door Problems...
Discussion in 'General Chevy & GM Tech Questions' started by clane493, Jul 10, 2010.
  1. clane493
    clane493 New Member
    Just bought a 2005 Yukon XL in April. About 1 month ago the driver's side door started to click VERY loudly when opening. The clicks happen at each hinge stopping position (about 3). Tried WD-40 but doesn't work. My extended warranty doesn't cover door issues. Hoping maybe to find out some fixes.
  2. 99'HEARTBEAT
    I had the Same problem with my Driver Side Door.I tired everything,you name it .....I ended up putting on a New Hinge.
  3. clane493
    clane493 New Member
    Thanks for the info '99! Do you mind me asking how much did the new hinge cost and were you able to do the work yourself?
  4. 99'HEARTBEAT
    I want to said.....somewhere around $25.00-$30.00.......It took me about 10-15 mins to remove the old hinge and to install the new hinge.....Not hard at all.
  5. silveradotrailblazer
    Sounds like what was happening on my wifes Trailblazer driver side passenger door. I tried lubing the exposed part of hinge, didnt help. Than I removed the rubber seal around the hinge ( it just slides off on the Trailblazers) put the window up and sprayed lube on the hinge part in side the door. It worked. Slide the rubber seal back on.
