2005 silverado abs light
Discussion in 'GM Electrical Tech' started by bacol14, Jul 26, 2010.
  1. bacol14
    bacol14 Rockstar
    my 2005 chevy silverado abs light will not shut off. It happened a couple times right after I put my lift in, some of the cables needed to be tied down.
    Now everything looks fine and my abs light wont shut off... before I spend my money at a shop I wanted to know if anyone has any ideas whats wrong...
    Thanks guys
  2. hundojoe
    hundojoe Rockstar 100 Posts
    My guess is that with your new lift the abs wires that run to the front wheel bearings were pulled out of the bearing assembly itself or the wires got streched or pinched and are broken now, See if the junk man has any used ones laying around, thats where I would start. good luck.
  3. senorbob999
    senorbob999 New Member
    its either the speed sensor in your wheel bearings or the wheel bearings themselves. or like mentioned above the harness got stretched. a good way to test your wheel bearing is by jacking up your truck with a floor jack on a level surface. once thats done go to each of your front tires and lift them from the bottom going up. if theres any play or movement up or down you may need to replace the wheel bearings. the worst case senario would be the abs module. its pricey so beware.
  4. silveradotrailblazer
    Did you reprogram the trucks computer for the new taller tires? If you didn't than that can throw a ABS code.
