2006 Silverado 5.3 crew cab. P0175 Diagnosis reading
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by bryguy39, Mar 5, 2012.
  1. bryguy39
    bryguy39 New Member
    Can anyone help me as to what is probably the issue? The truck runs and drives dont stall, but can tell its kind of sluggish. The Check engine light came on and was Diagnosed P0175 saying rich in bank 2.
    Any help would be greatfully appreciated.
    Thanks,Bryan
  2. sstoner911
    Could be a bad o2 sensor. But I would maybe start with plugs etc....
  3. mfleetwood
    Probably more info than you need, but should get you taken care of....
    P0175 OBD-II Trouble Code
    Technical Description
    System Too Rich (Bank 2)
    What does that mean?
    Basically this means that an oxygen sensor in bank 2detected a rich condition (too little oxygen in the exhaust). On V6/V8/V10 engines, Bank 2 is the side of the engine that doesn't have cylinder #1.
    Note: This DTC is very similar to P0172, and in fact your vehicle may show both codes at the same time.
    Symptoms
    You will more than likely not notice any drivability problems, although there may be symptoms such as a misfire.
    Causes
    A code P0175 may mean that one or more of the following has happened:
    • The MAF (Mass Air Flow) Sensor is dirty or faulty. Note: The use of "oiled" air filters can cause the MAF to become dirty if the filter is over-oiled
    • There could be a vacuum leak.
    • There could be a fuel pressure or delivery problem
    Possible Solutions
    Possible solutions include:
    • Inspect all vacuum and PCV hoses, replace if necessary
    • Clean the MAF sensor. Consult your service manual for it's location if you need help. I find it's best to take it off and spray it with MAF cleaner only. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling
    • Inspect fuel lines for cracks, leaks, or pinches
    • Check the fuel pressure at the fuel rail
    • Check the fuel injectors, they may be dirty. Use fuel injector cleaner or get them professionally cleaned/replaced.
    • Check for an exhaust leak before the first oxygen sensor (this is unlikely to cause the problem, but it is possible)
  4. ChevyFan
    Thread moved. This is not a customer service issue, moved to the proper forum.
