2007 Silverado tail light
Discussion in 'GM Electrical Tech' started by cooner, Sep 9, 2012.
  1. cooner
    cooner New Member
    I have a 2007 Silverado Clasic and the right (passenger side) tail light doesn't work. Blinker, brake light and all work fine. Tried 2 new bulbs and the tail light filiment does not light up. Any suggestions would be greatly appreciated. THANKS
  2. rileyjr16
    Have you checked your fuses? And checked to make sure the wiring harness is all plugged up and tight? It is right above the spare under the bed
  3. cooner
    cooner New Member
    Checked the wiring harness but not the fuses...which one would be for the right tail light?
  4. 99'HEARTBEAT
    The Fuses for the Taillights are Located in the Fuse Box, in the Engine Bay, and on the Back-side of the Fuse Box Cover, is a Diagram of All the Fuses.
  5. cooner
    cooner New Member
    On the back side of the cover none are marked 'rt tl' or anything that resembles right tail light. Looked in the owners manual and it didn't show one.
  6. Pikey
    I know that 07 was a model change. But, my 2002 had the same issue. It turned out to be where the rear harness connects to the harness from the front. Mine was located on the frame cross member just obove the spare tire. I pulled the connector apart and sprayed some contact cleaner on both sides. Then I smeared some grease on it and reassembled it. I had to use a Zip tie to hold it together because the clip was weak.
