2007 uplander fuel system problem: pump has 62 psi at tank, engine won't run.
Discussion in 'General Chevy & GM Tech Questions' started by jonathan1962, Nov 26, 2012.
  1. jonathan1962
    jonathan1962 New Member
    Jon b here, Palmdale ca.
    my 2007 uplander ran out of gas. i added 4 gallons to the tank (roadside) and the engine won't start.
    i dropped the gas tank and tested the fuel pump pressure at 62 p.s .i..
    Still won't start, no fuel to the engine.
    I tried to check fuel pressure at the green capped schrader valve but nothing at all comes out when I depress the needle.
    Any suggestions?
  2. 1953bowtieguy
    1953bowtieguy Rockstar 4 Years 500 Posts
    Welcome to GMTC. Have you checked your feul pump and also have you filled it yet. Also a hint for next time dont run out of gas.
  3. jonathan1962
    I have checked the fuel pump at the tank. Specs list required pressure at 56-62 P.S.I..
    Where do I check pressure from at the engine? And it was my wife who ran out of gas.
  4. SurrealOne
    Sorry to hear you're having wife-induced troubles. I can't help with the issue but wanted to welcome you to GMTC! :great:
  5. donyms
    Welcome to the club, it's good to have you aboard. :glasses:
  6. retired2001
    Welcome to the G M T C !
  7. MrShorty
    If you have pressure at the pump, but not at the Schrader valve, that suggests to me either something blocking fuel flow to the engine. I would actually hook your pressure gauge up to the Schrader valve and run the pump to see if the system generates pressure. Have you checked the fuel filter? Kinks or other damage to the supply line?
    The other possibility that comes readily to mind is if the regulator is stuck open. Carefully (so as not to damage the return line) pinch off a soft spot in the return line and run the pump to see if that induces the pressure to come up. If you get no pressure with the return line open, but pressure builds up when the return line is closed, that suggests that the regulator is stuck open (I'm assuming at this point that you '07 still uses the continuously circulating fuel system like my '98).
