2008 Chevy silverado light knob help
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Tricitydeals, Feb 28, 2013.
  1. Tricitydeals
    Tricitydeals New Member
    I have a 2008 silverado and I just noticed that the knob that turns the light on/off/auto and the know for the interior lights is push in. How to i pop in back into place.
  2. RayVoy
    Hard to follow what your asking.
    Do you have 2 switches that are "pushed in"? Help us out.
  3. Tricitydeals
    A picture is worth a thousand words.
  4. tbplus10
    If I remember correctly there's clips behind the panel that hold the switch's in place, I think those clips are plastic, which would mean they break easily.
    I've hit that switch with my knee once or twice and worried about doing the same thing.
  5. Tricitydeals
    How do I get to it? Does that entire plate come out or do I need to disassemble the skirt?
  6. stchman
    You have what appears to be an LTZ interior. You will need to remove the lower part of the dash on the drivers side. After that you will be able to un-clip the piece that holds the light switch assembly.
  7. Tricitydeals
    I do have a LTZ. I got lucky, I was able to pop the fuse panel on the side and access it. i used a pencil to guide and snap it back into place. It appears there are no broken clips.
    Thanks for everyone's help.
  8. RayVoy
    We all learned something today, thanks for sharing.
    If it happens again, the trim piece just below the switches, will easily remove.
  9. stchman
    That's good to know, the fuse panel. Will have to remember that.
  10. Robert55
    Robert55 New Member
    Just brought a used 2008 Silverado, I just notice I have the same problem. Can you use Screw Drive instead of a pencil?
