2008 gmc sierra 4.8l wont crank
Discussion in 'GM Powertrain' started by fender_fan969, Dec 28, 2010.
  1. fender_fan969
    fender_fan969 New Member
    go to turn the key and nothing happens everything seems to have power does anyone know what could cause this
  2. mfleetwood
    It could be a number of things. I recently had a battery problem with my 2008, especially after I would let my truck sit for a few days. I think that if the battery power drops low enough, it could still run the accessories but not have enough power to kick over the starter. Do you have a way to test the battery? I know my charger tells me how much % of power is left in the battery. When mine was acting up, it was reading about 20% or less and wouldn't hold a full charge for very long. I ended up replacing my battery which solved the problem.
  3. garth stuart
    garth stuart New Member
    Seen a lot of issues with underhood electrical centers having water in them.
  4. jreagan
    jreagan Rockstar
    Could be battery already mentioned, but you have an 08. I'd expect the OEM to last just a touch longer... I just replaced the OEM in my 04 Silv. It only had 9 volts. :)
    If the battery tests OK, then check the cables leading to the solenoid and starter. Also check the ground cable from the battery down to the frame.
