2009 work truck - brake noise
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by dark star, Apr 30, 2013.
  1. dark star
    dark star Member
    I'm getting a persistent squeak from the driver side rear brake upon release of the brake pedal.
    The brakes make no noise, simply a squeak on release only.
    Any idea's ?
  2. Z71_guy
    Disc or Drum, Either way i would lube up all the moving parts and contact points first easy and cheap fix
  3. j cat
    when the brakes make noise when the pedal is NOT depressed then the pad wear indicators are causing the issue. soon these indicator clips will fall off and the noise will go away
  4. Trucking
    Trucking Member
    Take off the DRUM and lube the backing plate lightly where the SHOE moves against it.
  5. kk wilson4
    kk wilson4 New Member
    spray it with brake cleaner
  6. Lerch98
    Lerch98 Member
    My rear brakes on my 05 squeak when backing up. Thanks for the tip, I'll check this.
