2010 crew cab door noise.
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Eviljay, Oct 2, 2010.
  1. Eviljay
    Eviljay New Member
    This is not the road noise problem, however it sounds more like the door is loose. When I hit bumps the door makes a creaking noise. This it the first GM I have ownwd in 8 years, but the volkswagon I had was like a vault when I closed the door. Is this normal fit and finish for a GM. I hope not.
  2. stephan
    No Eviljay, Not normal fit & finish for a GM. It sounds like you have smth that GM can fix under your warranty for you. Take the service manager for a ride and be sure and drive on the type of road where he is guranteed to hear the noise you're talking about.
    You're right about VW's being tight. I worked for Porche/Audi/VW and it's all about the weather stripping, the hinges & the latches.
  3. jake's silverado
    jake's silverado Epic Member 5+ Years 500 Posts
    they will probably lube the weatherstrip and it will go away for awhile.
