2010 Sierra fog lights?? I have the spot on the dial but no lights, are the wires the
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Falcone, Sep 3, 2010.
  1. Falcone
    Falcone Rockstar 100 Posts
    So I just got my 2010 Sierra nevada edition. Love it, but didn't want to opt for the factory fogs. Now there is the spot on my light wheel to turn non the fog lights and the dial goes to it and all. I'm wondering if the wireing for the lights would have been run but just no lights put it? How do I take the plastic covers off to check without damage?
  2. jake's silverado
    jake's silverado Epic Member 5+ Years 500 Posts
    My 07 and 09 silverados has the fog lamps as a push button on the interior light dimmer not the headlamp dial!
  3. Falcone
    Mine is definatly on the dial I believe. symbol that looks like D\\ but the lines are coming from the center of the "lamp". My interior lamp dimmer/button just has a picture of the lightbulb with lines coming off of it.
  4. troutbug
    troutbug Rockstar 100 Posts
    I searched this before to see about doing this on my truck. If I remember right, it said the relay and fuse are already installed in the fuse block, along with the wiring to the dashboard. All you had to do is purchase the kit that includes the fog lamps, dash switch, and harness to connect to the fuse block. As far as the dash switch goes, on my truck (2008 chevy) the fog lamp switch would be located beneath the dimmer switch. The one above the dimmer is the dome light cancel button. The headlight dial only has options for: completely off, automatic, parking lights, and headlights...in that order. Your truck may be different, but if not, I don't think it matters because the replacement switch that includes the fog lights and the headlight switch is all one unit together. Hope this helps.
