2011 Silverado headlight lens removal
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by Jaele, May 20, 2012.
  1. Jaele
    Jaele Rockstar 100 Posts
    Has only tried this on a nnbs headlight? Im thinking about trying the oven way later this week. If anyone have done this do you have a how to? i can only find them on nbs and obs styles.
    Thanks
  2. AMac
    AMac Rockstar 3 Years GMTC Chick 500 Posts ROTM Winner
    This is fairly easy to do however you have to remove the grille and the grille clips can be a pain. there is a 10mm bolt down low that is reachable through the wheel-well. Then I think there are two top bolts to remove.
    The following video should be able to guide you through the process.
    http://www.youtube.com/watch?v=L_eLaZpqyDA
    ---------- Post added at 04:02 PM ---------- Previous post was at 03:56 PM ----------
    re-reading the post/thread title, I don't think I answered your question. You are obviously asking about the lens and not headlight removal from the truck, sorry about that.
  3. Jaele
    LOL its ok, I took it apart the other night to see what i was getting into. But yes im trying to remove the amber lens in the actual headlight
  4. SurrealOne
    Based on experience with the NBS headlights, I don't recommend the oven method. I've personally found it just makes the plastic warm and annoying to handle ... for what little it helps with the adhesive. Now a heat gun is a different story and I do use one of those while working the material in localized areas.
