2015 GMC Yukon & Yukon XL Spec Sheet
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by ChevyFan, Sep 13, 2013.
  1. ChevyFan
    2015 GMC Yukon & GMC Yukon XL Specifications
    [FONT=Arial, sans-serif]PRELIMINARYSPECIFICATIONS[/FONT]
    [FONT=Arial, sans-serif]Overview[/FONT]
    [TABLE="width: 577"]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Models: [/FONT]
    [/TD]
    [TD="width: 424"] [FONT=Arial, sans-serif]GMC Yukon, Yukon XL; Yukon Denali and Yukon XL Denali [/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Construction:[/FONT]
    [/TD]
    [TD="width: 424"] [FONT=Arial, sans-serif]body on frame[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Manufacturing location: [/FONT]
    [/TD]
    [TD="width: 424"] [FONT=Arial, sans-serif]Arlington, Texas [/FONT]
    [/TD]
    [/TR]
    [/TABLE]
    [FONT=Arial, sans-serif]Powertrains[/FONT]
    [TR]
    [TD="width: 123"]
    [/TD]
    [TD="width: 202"] [FONT=Arial, sans-serif]EcoTec3 5.3L V-8 FlexFuel (L83)[/FONT]
    [/TD]
    [TD="width: 208"] [FONT=Arial, sans-serif]EcoTec3 6.2L V-8 FlexFuel (L86) [/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Fuel delivery: [/FONT]
    [/TD]
    [TD="width: 202"] [FONT=Arial, sans-serif]direct fuel injection with Active Fuel Management[/FONT]
    [/TD]
    [TD="width: 208"] [FONT=Arial, sans-serif]direct fuel injection with Active Fuel Management[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Horsepower (hp / kW @ rpm): [/FONT]
    [/TD]
    [TD="width: 202"] [FONT=Arial, sans-serif]355 / 250 @ 5600 (est.)[/FONT]
    [/TD]
    [TD="width: 208"] [FONT=Arial, sans-serif]420 / 313 @ 5600 (SAE certified)[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Torque (lb-ft / Nm @ rpm): [/FONT]
    [/TD]
    [TD="width: 202"] [FONT=Arial, sans-serif]383 / 519 @ 4100 (est.)[/FONT]
    [/TD]
    [TD="width: 208"] [FONT=Arial, sans-serif]460 / 623 @ 4100 (SAE certified)[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Estimated fuel economy:[/FONT]
    [/TD]
    [TD="width: 202"] [FONT=Arial, sans-serif]TBD[/FONT]
    [/TD]
    [TD="width: 208"] [FONT=Arial, sans-serif]TBD[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Transmission: [/FONT]
    [/TD]
    [TD="width: 202"] [FONT=Arial, sans-serif]Hydra-Matic 6L80 6-speed auto. [/FONT]
    [/TD]
    [TD="width: 208"] [FONT=Arial, sans-serif]Hydra-Matic 6L80 6-speed auto.[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Final drive ratio: [/FONT]
    [/TD]
    [TD="width: 202"] [FONT=Arial, sans-serif]3.42[/FONT]
    [/TD]
    [TD="width: 208"] [FONT=Arial, sans-serif]3.42[/FONT]
    [/TD]
    [/TR]
    [/TABLE]
    [h=2][/h][h=2][FONT=Arial, sans-serif]Chassis/ Suspension & Brakes[/FONT][/h][TABLE="width: 577"]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Front: [/FONT]
    [/TD]
    [TD="width: 424"] [FONT=Arial, sans-serif]independent coil-over-shock; twin-tube shock absorbers[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Rear:[/FONT]
    [/TD]
    [TD="width: 424"] [FONT=Arial, sans-serif]solid axle with semi-elliptic, variable-rate, two-stage multileaf springs; splayed shock absorbers[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Steering type: [/FONT]
    [/TD]
    [TD="width: 424"] [FONT=Arial, sans-serif]electric power-assisted rack-and-pinion [/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Brakes: [/FONT]
    [/TD]
    [TD="width: 424"] [FONT=Arial, sans-serif]power-assisted, four-wheel disc, four-wheel ABS, with [/FONT][FONT=Arial, sans-serif]Duralife™ rotors; vented front and rear rotors[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Wheel size & type / tire size:[/FONT]
    [/TD]
    [TD="width: 424"] [FONT=Arial, sans-serif]18 x 8.5-in. aluminum / [/FONT][FONT=Arial, sans-serif]P265/65R18[/FONT]
    [FONT=Arial, sans-serif]20 x 9.0-in. aluminum / [/FONT][FONT=Arial, sans-serif]P275/55R20[/FONT]
    [FONT=Arial, sans-serif]22 x 9.5-in. aluminum / [/FONT][FONT=Arial, sans-serif]P285/45R22[/FONT]
    [/TD]
    [/TR]
    [/TABLE]
    [FONT=Arial, sans-serif]Exterior[/FONT]
    [TR]
    [TD="width: 129"]
    [/TD]
    [TD="width: 214"] [FONT=Arial, sans-serif]Yukon / Yukon Denali [/FONT]
    [/TD]
    [TD="width: 190"] [FONT=Arial, sans-serif]Yukon XL / Yukon Denali XL [/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 129"] [FONT=Arial, sans-serif]Wheelbase (in / mm): [/FONT]
    [/TD]
    [TD="width: 214"] [FONT=Arial, sans-serif]116 / 2946[/FONT]
    [/TD]
    [TD="width: 190"] [FONT=Arial, sans-serif]130 / 3302[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 129"] [FONT=Arial, sans-serif]Overall length (in / mm): [/FONT]
    [/TD]
    [TD="width: 214"] [FONT=Arial, sans-serif]203.9 / 5179[/FONT]
    [/TD]
    [TD="width: 190"] [FONT=Arial, sans-serif]224.3 / 5697[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 129"] [FONT=Arial, sans-serif]Overall width (in / mm):[/FONT]
    [/TD]
    [TD="width: 214"] [FONT=Arial, sans-serif]80.5 / 2044[/FONT]
    [/TD]
    [TD="width: 190"] [FONT=Arial, sans-serif]80.5 / 2044[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 129"] [FONT=Arial, sans-serif]Overall height (in / mm)[/FONT]
    [/TD]
    [TD="width: 214"] [FONT=Arial, sans-serif]74.4 / 1889[/FONT]
    [/TD]
    [TD="width: 190"] [FONT=Arial, sans-serif]74.4 / 1889[/FONT]
    [/TD]
    [/TR]
    [/TABLE]
    [h=2][FONT=Arial, sans-serif]Interior[/FONT][/h][TABLE="width: 577"]
    [TR]
    [TD="width: 123"]
    [/TD]
    [TD="width: 130"] [FONT=Arial, sans-serif]First Row[/FONT]
    [/TD]
    [TD="width: 124"] [FONT=Arial, sans-serif]Second Row[/FONT]
    [/TD]
    [TD="width: 142"] [FONT=Arial, sans-serif]Third Row[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Headroom (in / mm): [/FONT]
    [/TD]
    [TD="width: 130"] [FONT=Arial, sans-serif]Yukon: 42.8 / 1087[/FONT]
    [FONT=Arial, sans-serif]Yukon XL: 42.8 / 1087[/FONT]
    [/TD]
    [TD="width: 124"] [FONT=Arial, sans-serif]Yukon: 38.7 / 983[/FONT]
    [FONT=Arial, sans-serif]Yukon XL: 39.1 / 993[/FONT]
    [/TD]
    [TD="width: 142"] [FONT=Arial, sans-serif]Yukon: 38.1 / 967[/FONT]
    [FONT=Arial, sans-serif]Yukon XL: 38.5 / 978[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Legroom (in / mm):[/FONT]
    [/TD]
    [TD="width: 130"] [FONT=Arial, sans-serif]Yukon: 45.3 / 1150[/FONT]
    [FONT=Arial, sans-serif]Yukon XL: 45.3 / 1150 [/FONT]
    [/TD]
    [TD="width: 124"] [FONT=Arial, sans-serif]Yukon: 39 / 990[/FONT]
    [FONT=Arial, sans-serif]Yukon XL: 39.7 / 1008[/FONT]
    [/TD]
    [TD="width: 142"] [FONT=Arial, sans-serif]Yukon: 24.8 / 630[/FONT]
    [FONT=Arial, sans-serif]Yukon XL: 34.5 / 876[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Max cargo room – seats folded (cu ft / L):[/FONT]
    [/TD]
    [TD="width: 130"] [FONT=Arial, sans-serif]Yukon: 94.7 / 2681[/FONT]
    [FONT=Arial, sans-serif]Yukon XL: 121.1 / 3429[/FONT]
    [/TD]
    [TD="width: 124"] [FONT=Arial, sans-serif]Yukon: 51.7 / 1464[/FONT]
    [FONT=Arial, sans-serif]Yukon XL: 76.4 / 2163[/FONT]
    [/TD]
    [TD="width: 142"] [FONT=Arial, sans-serif]Yukon: 15.3 / 433[/FONT]
    [FONT=Arial, sans-serif]Yukon XL: 38.8 / 1098[/FONT]
    [/TD]
    [/TR]
    [/TABLE]
    [h=2][FONT=Arial, sans-serif]Capacities[/FONT][/h][TABLE="width: 577"]
    [TR]
    [TD="width: 123"]
    [/TD]
    [TD="width: 196"] [FONT=Arial, sans-serif]Yukon / Yukon Denali[/FONT]
    [/TD]
    [TD="width: 214"] [FONT=Arial, sans-serif]Yukon XL / Yukon XL Denali[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Curb weight (lb / kg):[/FONT]
    [/TD]
    [TD="width: 196"] [FONT=Arial, sans-serif]5349 / 2426 (2WD w/ 20-in. wheels)[/FONT]
    [FONT=Arial, sans-serif]5585 / 2533 (4WD w/ 20-in. wheels)[/FONT]
    [FONT=Arial, sans-serif]5496 / 2493 (Denali 2WD)[/FONT]
    [FONT=Arial, sans-serif]5746 / 2606 (Denali AWD)[/FONT]
    [/TD]
    [TD="width: 214"] [FONT=Arial, sans-serif]5576 / 2529 (2WD w/ 20-in. wheels)[/FONT]
    [FONT=Arial, sans-serif]5815 / 2637 (4WD w/ 20-in. wheels)[/FONT]
    [FONT=Arial, sans-serif]5717 / 2593 (Denali 2WD)[/FONT]
    [FONT=Arial, sans-serif]5981 / 2713 (Denali AWD)[/FONT]
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] [FONT=Arial, sans-serif]Max trailer towing (lb / kg): [/FONT]
    [/TD]
    [TD="width: 196"] [FONT=Arial, sans-serif]8500 / 3855 (2WD)[/FONT]
    [FONT=Arial, sans-serif]8300 / 3765 (4WD)[/FONT]
    [FONT=Arial, sans-serif]8300 / 3765 (Denali 2WD)[/FONT]
    [FONT=Arial, sans-serif]8100 / 3674 (Denali AWD)[/FONT]
    [/TD]
    [TD="width: 214"] [FONT=Arial, sans-serif]8300 / 3765 (2WD)[/FONT]
    [FONT=Arial, sans-serif]8000 / 3628 (4WD)[/FONT]
    [FONT=Arial, sans-serif]8000 / 3628 (Denali 2WD)[/FONT]
    [FONT=Arial, sans-serif]7800 / 3538 (Denali AWD)[/FONT]
    [/TD]
    [/TR]
    [/TABLE]
    [FONT=Arial, sans-serif]Note:Information shown is current at time of publication.[/FONT]
  2. tbplus10
    The big boy on the block, the XL, which is normally considered the best towing platform doesnt have the highest weight rating.
    3.42 gears with 22"/P285 wheels/tires might be a bit of a dog when towing 7800 to 8500lbs even with the 6.2ltr. Im certain it wont be a roadrunner towing that weight with the 5.3.
  3. unsub
    unsub Member 1 Year
    Always cool to see the specs of the new year, but honestly, how many of us are going have 60k+ after taxes to drop on a new one? New suburban prices are a rich man's game, that's why as a non-rich man I love the fact that these depreciate so much so folks like most of us can afford a 5-10 year old model with 50-125k at a great price.
    I look at the specs of new vettes as well so I know what I will be dealing with in 10 years when I buy one.
  4. unsub
    unsub Member 1 Year
    OK Steve, three different posts on the same thing is plenty.
  5. ChevyFan
    This is raw data straight from GM and it's subject to change. We'll try to monitor this over time and will let you know if we get alerted to any changes for the 2015 release.
    Overview
    [TR]
    [TD="width: 123"] Models:
    [/TD]
    [TD="width: 424"] GMC Yukon, Yukon XL; Yukon Denali and Yukon XL Denali
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] Construction:
    [/TD]
    [TD="width: 424"] body on frame
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] Manufacturing location:
    [/TD]
    [TD="width: 424"] Arlington, Texas
    [/TD]
    [/TR]
    [/TABLE]
    Powertrains
    [TR]
    [TD="width: 123"]
    [/TD]
    [TD="width: 202"] EcoTec3 5.3L V-8 FlexFuel (L83)
    [/TD]
    [TD="width: 208"] EcoTec3 6.2L V-8 FlexFuel (L86)
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] Fuel delivery:
    [/TD]
    [TD="width: 202"] direct fuel injection with Active Fuel Management
    [/TD]
    [TD="width: 208"] direct fuel injection with Active Fuel Management
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] Horsepower (hp / kW @ rpm):
    [/TD]
    [TD="width: 202"] 355 / 250 @ 5600 (est.)
    [/TD]
    [TD="width: 208"] 420 / 313 @ 5600 (SAE certified)
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] Torque (lb-ft / Nm @ rpm):
    [/TD]
    [TD="width: 202"] 383 / 519 @ 4100 (est.)
    [/TD]
    [TD="width: 208"] 460 / 623 @ 4100 (SAE certified)
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] Estimated fuel economy:
    [/TD]
    [TD="width: 202"] TBD
    [/TD]
    [TD="width: 208"] TBD
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] Transmission:
    [/TD]
    [TD="width: 202"] Hydra-Matic 6L80 6-speed auto.
    [/TD]
    [TD="width: 208"] Hydra-Matic 6L80 6-speed auto.
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] Final drive ratio:
    [/TD]
    [TD="width: 202"] 3.42
    [/TD]
    [TD="width: 208"] 3.42
    [/TD]
    [/TR]
    [/TABLE]
    [TR]
    [TD="width: 123"] Front:
    [/TD]
    [TD="width: 424"] independent coil-over-shock; twin-tube shock absorbers
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] Rear:
    [/TD]
    [TD="width: 424"] solid axle with semi-elliptic, variable-rate, two-stage multileaf springs; splayed shock absorbers
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] Steering type:
    [/TD]
    [TD="width: 424"] electric power-assisted rack-and-pinion
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] Brakes:
    [/TD]
    [TD="width: 424"] power-assisted, four-wheel disc, four-wheel ABS, with Duralife™ rotors; vented front and rear rotors
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] Wheel size & type / tire size:
    [/TD]
    [TD="width: 424"] 18 x 8.5-in. aluminum / P265/65R18
    20 x 9.0-in. aluminum / P275/55R20
    22 x 9.5-in. aluminum / P285/45R22
    [/TD]
    [/TR]
    [/TABLE]
    Exterior
    [TR]
    [TD="width: 129"]
    [/TD]
    [TD="width: 214"] Yukon / Yukon Denali
    [/TD]
    [TD="width: 190"] Yukon XL / Yukon Denali XL
    [/TD]
    [/TR]
    [TR]
    [TD="width: 129"] Wheelbase (in / mm):
    [/TD]
    [TD="width: 214"] 116 / 2946
    [/TD]
    [TD="width: 190"] 130 / 3302
    [/TD]
    [/TR]
    [TR]
    [TD="width: 129"] Overall length (in / mm):
    [/TD]
    [TD="width: 214"] 203.9 / 5179
    [/TD]
    [TD="width: 190"] 224.3 / 5697
    [/TD]
    [/TR]
    [TR]
    [TD="width: 129"] Overall width (in / mm):
    [/TD]
    [TD="width: 214"] 80.5 / 2044
    [/TD]
    [TD="width: 190"] 80.5 / 2044
    [/TD]
    [/TR]
    [TR]
    [TD="width: 129"] Overall height (in / mm)
    [/TD]
    [TD="width: 214"] 74.4 / 1889
    [/TD]
    [TD="width: 190"] 74.4 / 1889
    [/TD]
    [/TR]
    [/TABLE]
    Interior
    [TR]
    [TD="width: 123"]
    [/TD]
    [TD="width: 130"] First Row
    [/TD]
    [TD="width: 124"] Second Row
    [/TD]
    [TD="width: 142"] Third Row
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] Headroom (in / mm):
    [/TD]
    [TD="width: 130"] Yukon: 42.8 / 1087
    [/TD]
    [TD="width: 124"] Yukon: 38.7 / 983
    [/TD]
    [TD="width: 142"] Yukon: 38.1 / 967
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] Legroom (in / mm):
    [/TD]
    [TD="width: 130"] Yukon: 45.3 / 1150
    [/TD]
    [TD="width: 124"] Yukon: 39 / 990
    [/TD]
    [TD="width: 142"] Yukon: 24.8 / 630
    [/TD]
    [/TR]
    [TR]
    [TD="width: 123"] Max cargo room – seats folded (cu ft / L):
    [/TD]
    [TD="width: 130"] Yukon: 94.7 / 2681
    [/TD]
    [TD="width: 124"] Yukon: 51.7 / 1464
    [/TD]
    [TD="width: 142"] Yukon: 15.3 / 433
    [/TD]
    [/TR]
    [/TABLE]
    - - - Updated - - -
    Not sure how this got double posted.
  6. CKNSLS
    CKNSLS Rockstar 100 Posts
    The best towing platform was the Suburban 2500.
