245 on a 8" rims
Discussion in 'Lifted & Offroad Suspension' started by ridick_bowen, Mar 7, 2011.
  1. ridick_bowen
    ridick_bowen Rockstar 100 Posts
    Can anyone confirm that a 245 tire will fit on a 8" wide rim?
  2. clgoch187
    clgoch187 Rockstar 4 Years 500 Posts
    yup...no problem
  3. mfleetwood
    X2, yes it will fit. Here is some info if you want to double check (I used 70/17s, so you will have to enter the size you are looking for.
    Stock Tire - 245/70R17
    Section Width: 9.64 in 245 mm
    Rim Diameter: 17 in 431.8 mm
    Rim Width Range 6.5 - 8 in
    Overall Diameter: 30.50 in 774.7 mm
    Sidewall Height: 6.75 in 171.45 mm
    Radius: 15.25 in 387.35 mm
    Circumference: 95.81 in 2433.5 mm
    Revs per Mile: 681.9
  4. silveradotrailblazer
    Yes they will fit. Have 275/45-20's on my wifes Trailblazer with 20X8 Helo's so the 245 will be fine on a 8" wheel.
  5. MrShorty
    Can I add another, "yes, they will fit fine." with another reason why. If you look at the specification sheets that tire manufacturers put out (some sites like tirerack have them, too), you will see that manufacturers usually like to see the rim width be between about 65% and 90% of the section width. 8 inches is about 200 mm, which is about 82% of 245 mm. Well within the accepted rim width for a 245 mm tire.
  6. 2COR517
    What's the aspect ratio?
