2500 4X4 Silverado cracked flywheel around all the bolts
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by j cat, Oct 23, 2013.
  1. j cat
    Had an issue with a vehicle loosing drive going at 60 mph steady on the road . prior to this ticking was heard....found the flywheel had cracked in a circle around the bolts causing the connection to the tranny to be lost..
    Any one ever seen this ? low miles below 100,000 miles ..
  2. Pikey
    I have seen it a few times. One was because of loose bell housing bolts and a bad tranny mount. There was also a missing dowel pin between the motor and trans. The other was blamed on a bad torque converter. (not real sure how they arrived at that diagnosis). I have heard of it happening when a guy swaps out his own trans and does not bother using the proper torque specs for the Torque converter to flywheel bolts.
  3. Conlan Rose
    Wow, and I've never heard of a cracked fly wheel. The flywheels are made of very hard and strong iron/steel. I would think the bolts would sheer before the fly wheel would break so there must of been a prior problem with it.
