2nd broken shock in a month!
Discussion in 'Lifted & Offroad Suspension' started by zachh1020, May 30, 2010.
  1. zachh1020
    zachh1020 Rockstar 100 Posts
    Hello everyone.
    About a month ago, I was hearing a clunking when I hit bumps. So I look when I get to work and and my front driver side shock has broken apart at the joint. I went in and had it replaced. Yesterday I heard that noise again and thought maybe the one on the other side had broken. I look once again and the new shock bolt and rubber bushing is missing, the stud on the top is bent and I looks like it is very close to coming apart at the joint.
    What could have caused this twice in about a month? I pretty much only drive on the highway to work and back and occasionally on a smooth gravel road to a friends house. Nothing crazy or off road. Hell, the shock is still so clean, I would eat off it. No mud!
    Any help is appreciated!
  2. ippielb
    Over tightening? Under Tightening?
  3. zachh1020
    Could have been under-tightened. After I got my truck back, I found a socket closed in the hood the same size needed for the shock bolt, almost as if they hadn't tightened yet. Just finger tight then forgot.
  4. murdog94
    Do you have a lift or leveling kit?? If so are the shocks the correct length???
  5. zachh1020
    Torsion bars are cranked about 1.5in in the front. They have been for over a year. Its kinda strange if it would be causing problems just now.
  6. murdog94
    YEah it is odd but a longer shock might solve your problem..
  7. zachh1020
    I'm having my torsion bars taken back down. I noticed the difference in the ride and it had bothered me for a year. I want a mostly smooth ride back.
  8. armandjones82
    armandjones82 New Member
    Try to find a durable GM Truck Parts, particularly on your shock. Researching on that kind of part can cause you to have a more time to look for products that are suitable for your truck. I think when you find the right shock for your truck, that would gradually help you to consume more and spend less in your truck parts!:)
