2wd to 4wd
Discussion in 'Chevy C/K Truck Forum' started by 99ta350, Dec 9, 2011.
  1. 99ta350
    99ta350 New Member
    I've got a 98 cheyenne regular cab. With the 4.3. Im wanting to make it 4wd. Any one ever do it this and have some insight on parts ill need and cost. Any input will be great
  2. ShadowRejects
    ShadowRejects Rockstar 100 Posts
    its very complicated, ive seen it done before but you might wanna ditch the IFS stuff and just do solid axle swap, So much easier, they do it alot on x-treme 4x4. but its VERY costly, your looking at the 3-6 thousand range
  3. aloxdaddy99
    X2 on what Shadow said. In most cases it is cheaper and easier to sell what you got and buy a 4x. It can be done. You need a transfer case that will mate up to your transmission. If one doesn't bolt right up you could call advanced adapters to have an adapter made. A front drive shaft, a front axle that has the diff in the proper location (if you go with a solid front axle) and I am sure I am missing a few things. Again it is doable just not cheap.
  4. silveradotrailblazer
    X3 solid axle!
  5. chico
    chico New Member
    Not a good choice for you,it's a lt's of work and and money and to be honest not worth it unless your truck is an absolute pristine shortbox,another downside is with the 4.3 not a good choice for a 4x4,your best option would be sell your truck and find a decent rebuildable 4x4.
  6. Scott_Anderson
    Scott_Anderson Rockstar 100 Posts
    +1 on what he said.
  7. 99ta350
    99ta350 New Member
    The thing is the money isn't my issue. I only have 600 in the truck. I've also got a 350 vortec complete with he computer and wire harness.
  8. project86
    project86 Member
    Find a truck close to the same year that has a good frame and four wheel drive. I bought an old truck with a bad transmission, swapped the body and everything else that wanted. Not the same year range but I've got 300 bucks in it plus my own personal wrench time.
  9. Jimmeh
    X2. Hell, if you can find the same exact truck, you can practically swap EVERYTHING over.
