2wd traction..
Discussion in 'Lifted & Offroad Suspension' started by udontknowjack, Apr 13, 2010.
  1. udontknowjack
    udontknowjack Rockstar
    what can i do to improve traction mild offroad in my 2wd truck? behind all terrain tires?
    i do 70% hwy 20% city and 10% off road ..... without trading in my truck to get a 4wd.....is there anything else i can do to improve my off road traction?
  2. ionspeedracer
    ionspeedracer New Member
    My daughter had the same issue...
    2wd pick up - I built a wood frame from 2 x 4s that had pockets to hold a 70 lb sandbag over each tire. Messes with your mileage a little, but she never slid out over the snowy winter!
  3. tbplus10
    Try dropping your tire pressure when you go off road, this gives you a bigger foot print and better traction.
    Try being easier on the gas pedal.
    And learn how to use the P brake to make the tire with the most traction spin instead of the tire with the least.
  4. Silverado Junkie
    Silverado Junkie Rockstar 4 Years 500 Posts
    Ive never heard of the parking brake trick but im gona have to try it.
  5. Pete95Sierra
    it may be worth it for you to install a limited slip diff in your rear axle. Or you can go all out and get a full locker. that means that both tires will always have power
  6. Big75
    Big75 Rockstar 4 Years 500 Posts
    auto locker in the rear. $250 - $300 works great on the street and locks up nicely off road.
  7. udontknowjack
    more info on this please.....maybe link....this sounds great.....
  8. udontknowjack
    you and me both buddy....
  9. lsutoms
    lsutoms Rockstar 100 Posts
    i have the same problem... i have an 09 2wd with nitto terra grapplers and i get stuck everywhere it seems like... got stuck in a gravel pit last weekend... barely pulled in the entrance to go fishing and wen tto leave and it wasnt thick at all i just started spinning... ive been stuck in someone's front yard, in a small sandy ditch, many other places n have only been driving since july... wish i would have spent the extra on the 4x4...
    i already have the limited slip diff and i dont find it help too good...
  10. Big75
    Here's your link... I use a powertrax in the rear of my truck and an aussie locker in the front. The basic Idea is the locker stays locked all the time until you take a turn. At that time the outside wheel frees up so not to wear on tires and driveline. these things are designed to give 100% power split between the wheels. they do make a clunk sound when engaging/disengaging nothing to worry about. costs less than an air locker, wont chew up the tires like a full locker, and posi is made to stay on the streets SERIOUSLY.
