3.73 to 4.56 Gear Swap
Discussion in 'GM Powertrain' started by Z71_usmc_rebel, Jun 26, 2008.
  1. Z71_usmc_rebel
    Z71_usmc_rebel Rockstar ROTM Winner 100 Posts
    I am wanting to swap my 3.73 to a 4.56..I have a site with gear packages and just want to get some feedback to see if yall think its a good deal or not. Also does anyone know what a shop would usually charge to do this swap?
    Here is the site/gear package.
    http://www.drivetrainwarehouse.com/PDT291625.aspx
  2. Crawdaddy
    looks about right, but I don't know of/ didn't check any of the cheap gear suppliers out there. However, it's right on line with 4wheelparts...
  3. Z71_usmc_rebel
    ok, im gonna look at 4wheelparts.com and see what they have to offer..
    Should anything else be replaced when swaping gears? the kit comes with master rebuild kit...Is that enough?
  4. finalday7
    finalday7 Epic Member 5+ Years ROTM Winner 1000 Posts
    The price is good. Check out accuautoparts.com for a couple more brands if you like. Also a shop will charge in the range of 450-900 to do front and rear.
  5. Z71_usmc_rebel
    OK thanks for that price quote...thats my biggest concern i dont want to be getting ripped off when i go to have the gears installed..but i also cant do it myself..lack of experience in that area and lack off time!
  6. tbplus10
    Check the origin of manufacturer. A few parts houses have been using Chinese manufactured gears and the quality on them has been terrible.
    The master rebuild/install kit should have everything you need to do the job. Before you buy the gears price them out and price out a few shops on install with parts and install without parts. Labor and parts from the shop will usually be the cheaper route, most shops have 2 different labor rates and charge a carry in parts surcharge if you supply the parts.
  7. Pete95Sierra
    i have heard good things about genuine gear. and just the master rebuild kit is all you will need. and the price looks about right too :great:
  8. collinsperformance
    collinsperformance Epic Member 5+ Years 500 Posts
    i would ask why the small tooth spread? bigger tires or towing......that might not be enough gear......and not worth the money.....mike
  9. Z71_usmc_rebel
    Im just looking to put the 6" lift and 35s on when i get home.. Are you saying i should go with a different gear?
  10. collinsperformance
    with 35" tires the 4:56 are the better gear or 4:88s just remember you got to do the front diff too to be able to use 4 wheel drive. this makes gear changes almost 2Xs the cost so a gear change just to change is way to expensive....mike
