    Join Today ~ It's Free
4.8L build to reach 375-385 hp, all motor!
Discussion in 'Performance & Fuel' started by Dontlookforme, Nov 30, 2010.
  1. Dontlookforme
    Dontlookforme New Member
    Looking to build a 4.8L Monster! I got one out of a junkyard and its sitting in my shop. Im pritty sure that the 4.8L, 5.3L, 6.0L motors are from the same cast iron block! i know that the 6.0L motors now make 345+ hp. So my goal for making 375-385 hp, is a possibility? Im looking to bore and stroke the 4.8L 292ci out to a 366ci or somthing as close as i can. While still having enough meat left to reuse the motor again. Any ideas or suggestions would be great!
    Thanks jason
  2. murdog94
    murdog94 New Member 1000 Posts
    Obviously a cam, and some porting on the heads, high output Injectors, better intake.
  3. stephan
    stephan New Member 1000 Posts
    What kind of fuel are you planning on running Jason? Pump gas?
  4. Dontlookforme
    Yes, pump gas. 93 octane.
  5. silveradotrailblazer
    silveradotrailblazer New Member 1000 Posts
    I believe the 4.8 and the 5.3 are the same block and the 6.0 is differant. You can bore the 6.0 more than the 4.8&5.3. Theres a reason you see most people using the 6.0 block for performance engine building.
  6. KWG08VMI
    KWG08VMI New Member
    I would go a little farther than just porting and polishing the heads, like maybe an entirely new set. I would start looking at full builds on LS1s and LS6s and see what you like and start from there.
  7. silveradotrailblazer
    Also on 4.8 & 5.3's theres a limit to what cylander heads you can use because of there small cylinder bore.
