4-speed upgrade to 5-speed
Discussion in 'Chevy C/K Truck Forum' started by Stubblejumper, May 1, 2012.
  1. Stubblejumper
    Stubblejumper New Member
    Hello, everyone. New to the site - I just bought a 1988 C30 4 x 4 with 7.4 liter and 4-speed manual transmission. I'd like to swap out the 4-speed for a 5-speed with overdrive and wonder if anyone else has done the same.
  2. 07XCSB
    07XCSB Active Member 2 Years 1000 Posts
    The NV4500 5spd is a good swap. Still gives you the granny low and a overdrive gear.
  3. Stubblejumper
    Thanks. I'm presuming the NV4500 will work with my existing transfer case - will I need a new clutch and bell housing?
  4. Boonduff
    I know it depends upon which transfercase you have. There was also several changes to the NV4500 over the years so it also matters which one you get. Give Advance Adapters a call @ 1-800-350-2223. They'll be able to tell which model years will swap the easiest and if any adapters will be needed.
