4 wheel drive
Discussion in 'Chevy C/K Truck Forum' started by andrew bookout, Mar 19, 2009.
  1. andrew bookout
    andrew bookout New Member
    when i put my truck intoo 4 hi and 4 low the truck will not come out of first gear. and when i put it into revers the back tires will lock up then start moving again but will make a loud poping sound before it starts to move again.
    also when im in drive and it wont go out of first gear it will make a loud pop then go into second gear.
    what would be the cause of this
  2. MrShorty
    Sounds like the drivetrain is binding up for some reason. Are you turning on pavement? Different sized tires? Is it possible someone has changed gear ratio/axle in front or rear so they no longer match?
  3. tbplus10
    Sounds a lot like two different gear ratios in the axles.
    Or something in the Tcase coming apart on the front drive section.
    It does move good in 2wd? Correct?
  4. andrew bookout
    yea it drives fine in 2wd but sometimes when u come to a complete stop and then start to move again it will pop then to.
  5. jim1958
    jim1958 Member
    Sounds like you got the transfer case blues, dude. Get ready to bend over and grab your ankles, it isn`t going to be pretty
