4wd clunk
Discussion in 'Lifted & Offroad Suspension' started by bry2500, Feb 4, 2009.
  1. bry2500
    Each time I drive in 4wd i hear a loud clunk, mostly during slow tight turning but also sometimes just when starting to move straight ahead.almost sounds like a u joint but super loud. I have checked every thin out and all seams tight and not worn. I know whata cv joint sounds like when it's going and this definitely is not a cv joint. I has almost a ping noise to it like if you were to push a dent out of sheet metal. Any thoughts?
    also it is mostly when driving in reverse and turning.
  2. GaryL
    4wd's don't like to turn tight when in 4wd, especially on dry pavement. A clunk in those situations is normal, but try to avoid them because it will damage the transfer case. The noise you hear when just starting out could be a little play in the transfer case. Someone else can probably help you some more.
  3. MrShorty
    Sounds like the 4wd binding up and releasing. Normal in 4H/4L on a good traction surface, though it does indicate that something will likely break if you continue the practice. 4H/4L should only be used when traction is poor enough to allow the wheels to slip.
    I had a truck do something similar when I had mis matched tires (same size but different manufacturer). The size difference between manufacturers was enough to cause the drivetrain to bind up and release with a clunk.
  4. bry2500
    I do have different manufacturer tires, they are the same size but the rear look a smidge smaller. I thought it was an optical illusion because of the front end rake on the avalanche. Looks like I have to find 4 new tires. Thanks for the quick replies guys.
    :great:
