4x4 switch controls - light problem?
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by Kraziken, Aug 22, 2010.
  1. Kraziken
    Kraziken Rockstar 100 Posts
    I have a '98 1500 4x4 with the pushbutton setup.
    Driving out to the beach today, I was getting a bit of fear because I would push the 4x4 button, and I could not tell if I was engaged. I hit the switch to go to 2WD and back to 4x4 hi, and finally felt it engage.
    Normally when switching, it should flash, then stay lit correct? At one point I had my wife get out to verify she could see all wheels spinning when I stepped on it. My controls don't light up.
    After being stopped, and starting back up, I noticed the 4x4 hi switch was illumintated. But then after awhile it turned off (no lights lit).
  2. murdog94
    There is probably a short in the switch, and you will most likely need to replace it. Another one of those common faults. But i would also let some others chim in on this just to be sure.
  3. jedepsub
    jedepsub Rockstar
    It just started doing it to me, 2Hi light would go out & would come back on when I hit a bump. I scanned it, did a transfer test all good. When I hit the dash the light would back on. I need to replace the switch.
  4. Kraziken
    Anyone know what part number the switch is?
    Part number 19168765 if anyone ever needs to look it up. About 50% cheaper online.
