5.3 Information Needed
Discussion in 'GM Powertrain' started by Thunderchild, Dec 9, 2009.
  1. Thunderchild
    Thunderchild Member
    Hello all, I have just inhereted a 2004 Tahoe LT. My brother was not too good on maintenance. I have checked all fluids and have had some fluid and filter changes done. I need to know about the engine. Does it have a rubber timing belt or is it chain? Also, when do you all have the rear diff fluid changed? I have done the front but the rear is very difficult to get to. Thanks in advance.
  2. 99'HEARTBEAT
    On the 5.3 it has a timing Chain and on changing the Rear Diff Fluid,Chevy said you can go 100,000 miles before its needs to be service.On my Truck I changed the Rear Diff Fluid at 50k.
  3. Thunderchild
    Thunderchild Member
    Yeah, I am at 90,000 just about so I figure i might as well do it now before the winter. What about the transfer case? What fluid for that and how often to change it? Thanks.
  4. s5belford
    s5belford Epic Member 5+ Years 1000 Posts
    in the owners manual there should be a maintenance schedule....
  5. Thunderchild
    Thunderchild Member
    You are right sir!! i will have to give it a good once over.
    :great:
