5.3L's that eat oil
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by fireman1317, Jun 26, 2010.
  1. 07subur
    07subur New Member
    Does anyone know if it is only the code 3 (aluminum)engines are affected or the code 0 (cast iron) as well? Can you put a code 0 engine in a vehicle that came with a code 3 engine? Any differences other than being heavier?
  2. RayVoy
    I don't know, but it is an interesting theory. The articles that I have found are all talking about aluminum.
    Should be do-able, the 2wd Avalanches use the iron engine, the 4x4 trucks use the aluminum.
  3. Sierraowner5.3
    Sierraowner5.3 Rockstar 4 Years 1000 Posts
    i thought if you had the flex fuel it was a iron block with aluminum heads?
    Alex
  4. PantheraUncia
    The hole AFM/ only using 4 cylinders is an interesting idea and might make sense for the newer 5.3L's but in 2000 we did not have the function to stop 4 of the 8 cylinders when we did not need them.... so my engine uses all 8 cylinders all the time, so that cannot be 100% of the truth about the problem.
  5. RayVoy
    Good point nakranij
  6. bazar01
    bazar01 Rockstar 100 Posts
    I have 2011 5.3L flex fuel and I have aluminum block.
  7. noshow13
    noshow13 New Member
    My 2005 uses about 1 quart every 3k miles too.
  8. 07subur
    07subur New Member
    No, mine is flex and is all aluminum
    Nico
  9. RayVoy
    I was answering an other thread, when I had a thought; maybe, along with AFM, it's the addition of ethanol to the gas that is causing the rings to stick
  10. bazar01
    So far, my new to me 2011 oil level has dropped a little below the top hole on the dipstick after 1500 miles. It looks good and promising. :great::happy:
