5.7-4.3 vortec intake mani gasket
Discussion in 'Chevy C/K Truck Forum' started by tbru323, Feb 10, 2013.
  1. tbru323
    tbru323 New Member
    I have a 97 silverado with the 5.7 and i recently did my intake manifold gasket, put the metal fel pro gasket in and torqued them all in sequence to spec. Still leaves a small puddle. I have been helping 2 of my buddys with blazers and the one is perfect after we did it and doesnt leak, the other has the same result as mine, still leaves a small puddle. Are these intakes [FONT=inherit ! important][FONT=inherit ! important][/FONT][/FONT]manifolds known for warping or pitting? i didnt notice any pitting on the 5.7 but the 4.3 that still leaks i checked and it had a little pitting but nothing that i felt would cause a problem. I could see the rtv seal getting weak but thats not a coolant bearing seal. This IMG has become a major headache for me and i have a feeling im not the only one. Any feedback would be greatly appreciated.
  2. Old Iron nut
    Old Iron nut New Member
    tbru, just acquired a 3500 model with the same problem, it's on it's second motor. Don't know what the problem is whether bad machining or bad gaskets. I just posted a msg regarding same. I don't have the motor out yet, but I know the pan is full of antifreeze. One of my customers had the same problem with his 350. The local rebuilder says that the gasket that GM uses is crap but the aftermarket ones are supposed to fix the problem. Hopefully the weather will mild up so that I can pull the motor. Cheers, Old Iron nut.
