6.0 or 5.3
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by drwdominance, Jun 4, 2010.
  1. drwdominance
    drwdominance Rockstar
    i have an 07 sierra classic. how do i know if it is a 6 or a 5.3? my insurance says it's an HD.
  2. murdog94
    there is an emmissions sticker under the hood that has the motors displacement. Also if you pull the RPO codes in the glove box... And you should be able to do a vin decoding and that would tell you as well.
  3. ChelleCaz
    ChelleCaz New Member
    Another way to tell is to look at your tailpipe. If your pipe goes out the passenger side to the right then you have the 5.3 if it goes straight out the back on the passenger side then you have the 6.0.
    I beleive the 6.0 in those trucks was called the Vortec Max. Somewhere around 360 hp and 381 Tq. Relatively impressive power and crappy mileage compared to the 5.3.
  4. drwdominance
    there seems to be a couple of stickers missing from under the hood. what is an rpo code?
  5. drwdominance
    ok. figured it out. vin # has t in it which makes it a 5.3. if it had a u then it would be the 6.0.
  6. murdog94
    Sounds good.. and the PRO code is a 3 digit code. There is a list of them on a sheet that is stuck to your glove box liner.. The codes tell you basically everything that you truck came with.
  7. 99'HEARTBEAT
    As Mentioned by Murdog94..[RPO Codes].....Are In your Glove Box....Enter your Trucks Vin # at the Site Below........It will show you what Engine you have...5.3 or 6.0.....Along with everything else your truck has on it...from the Factory.
    Link,
    http://www.compnine.com/vid.php
  8. 1flyfisher
    1flyfisher Rockstar 4 Years 100 Posts
    I have a new 2010 GMC Savana. I don't see any RPO codes in my glove box. Where are the RPO codes for my vehicle? ARe they somewhere else?
  9. 99'HEARTBEAT
    Hmm.....Being Van & a 2010....maybe G.M.did moved them to somewhere else on the Van's???.......:neutral:
  10. newsie23
    newsie23 New Member
    On my '03, the RPO numbers are on the rear surface of the front passenger door.
