6.2 diesel probs
Discussion in 'Chevy C/K Truck Forum' started by 83Sub, Nov 20, 2008.
  1. 83Sub
    83Sub New Member
    hey just put a new fuel pump on my suburban its got the 6.2 diesel and not starting should i crack all the injection lines open to prime the engine cause i cranked it over for a while but nothing, it started right up then died and can't get it started again
  2. 04sierracrewcab
    hopefully we can help solve your problem! :great:
    have you checked the pressure of the new pump???
  3. 83Sub
    83Sub New Member
    no not yet but i thought if u got air into the system u had to prime it.. but no not yet batteries died lol
  4. 04sierracrewcab
    im not sure on that
    u dont suppose that the battery being dead is the reason is it ?
  5. 83Sub
    83Sub New Member
    never had a prob like that the engine was warm...glow plugs work great just not getting the fuel part...
  6. 83Sub
    83Sub New Member
    but if theres any diesel mechanics out there that know a bit lol... not sure if i need to crack the injectors open to bleed the system
  7. EagleTalons
    EagleTalons Rockstar 100 Posts
    If you took the pump off you may have to prime it. Also by installing a new pump you may have some garbage plugging the line up!
    On a diesel tractor we ran all the fuel out of it (bad!) and it sucked a whole lotta dirt into the lines by doing that. Which when you put in the new pump you may have disturbed some garbage causing it to plug the line.
    Some advice would be to take and clean the diesel tubes and then prime them. Even if there is no garbage it could always use some cleaning!
  8. Pete95Sierra
    agreed you need to prime it and make sure it is clean. if you did that than crack the #1 injector and bleed the system of any air.
  9. Howie
    Howie Rockstar
    No start conditions on diesels are normally:
    Fuel Filter/Water Separator
    Bad fuel/Bacterial infestation
    Gelling of the fuel
    Air trapped in lines
    Bad injectors
    Bad fuel injection pump.
    Most likely air trapped in the lines. Crack your fuel lines at the injector, if possible. If a Crd system, you can try at the rail. Purge all air from the tank to the injector.
    Fill the tank, filters, pump, injector pump, injector.
    Also, It might be worth while to change the filters if you have had to replace the pump seeing as how your going to be under there anyway. And when you do, I reccomend adding one with a fram fuel/water separator that has the petcock, which will make bleeding the water off soo much easier.
  10. retired
    retired Rockstar 100 Posts
    Pull the fuel filter and make sure it's full of fuel. If full put it back on. Go get yourself a big can of W-D 40 and remove your air filter lid and have someone crank the engine while you use the W-D 40 to prime it. It may take a whole can. Good luck.
