6.2 engine swap
Discussion in 'GM Powertrain' started by 09silverado, Jun 20, 2012.
  1. 09silverado
    09silverado New Member
    I have a 2009 silverado that had a 5.3 lmg motor that I am wanting to swap with a l9h 6.2 from a gmc. I have the 6l80 tranny so it should be a direct swap but the l9h has vvt and I am wondering if I can just switch over ther timing chain sprocket and cover to eliminate the vvt and what advantages and disadvantages will it have?
    Also if I wanted to go with the vvt how would I go about since my ecu and harness was not equiped for vvt?
    The first pic is the one with vvt
      File size:
      84.2 KB
      File size:
      85.1 KB
  2. RallySTX
    RallySTX Member 100 Posts
    My guess would be that to make that swap work, you need the entire system, motor, harness, and ECM. Try what you asked about, and I suspect you will give your onboard ECM a lobotomy. But I'm just guessing, I have no experience with the newer trucks.
    Brian L.
