8 Lug 3/4 ton rearend
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by burbanguy, Jan 2, 2010.
  1. burbanguy
    burbanguy Rockstar
    I have an 87 Suburban and I just picked up the complete rearend from an 84 Chevy Truck that was at a junkyard. I also got the leaf springs bcuz they had 7 leafs and mines has only 5. (It's a half ton) And when we were taking off the parts, we noticed that the donor truck had a dual driveshaft setup and my Burbie is a straight through axle. I didn't pick up the dual setup bcuz I plan on trying 2 either use mine, or go to another yard and find drive shaft from another Burbie that has the 8 lug rearend on it already. Any suggestions?
  2. tbplus10
    What driveshaft length do you need?
    I think the 2 piece driveshaft is a different length than yours.
    Check the U-joints out also, if that new axle was from a 3/4 ton and you have a 1/2 ton Suburban theres a differenc in U-joint sizes, Google "Spicer U-joints" they recently put out a line of U-joint adaptors for swaps just like yours.
    Watch those leaf spring lengths, I dont remember them being the same length either.
    Also something about them rubbing on the stock exhaust.
  3. burbanguy
    burbanguy Rockstar
    Ok thanks. I heard that the leaf's should fit and as for them hitting my exhaust, I have a flowmaster that has no piping 2 it so that's not an issue. And I took the U- joints from the donor vehicle. Anymore advice?
  4. Willie G
    Willie G New Member
    Started to mention spring perch width, but then I re-read and saw it was a 3/4 to 1/2 swap.
    Nevermind. :sleep:
  5. burbanguy
    burbanguy Rockstar
    Yea, my truck is a 1/2 ton and I'm putting 3/4 ton parts on it. The springs seemed to be the same width where they are mounted at.
    Shouldnt that say 1/2 to 3/4 swap ?????????????????????????:lol:
  7. tbplus10
    You might need to put a manual BPV on the rear brakes.
    Your going to larger shoes with the new rear axle (which is a good thing) but the factory master cylinder and BPV dont know this and are set-up for the original axle.
  8. burbanguy
    burbanguy Rockstar
    Oh ok. I light just get a new/rebuilt master cylinder from Autozone or Kragen/Oriely and get the bpv from a junkyard. Man, those rear brake cables r a headache to take off.
  9. tbplus10
    Rebuilt/Reman Master cylinder will work.
    I prefer the manual adjustable BPV's from Summit, they offer added adjustability to the brake system.
  10. burbanguy
    burbanguy Rockstar
    Ok, thanks guys:)
