82 K10 Tail and Reverse Lights Not Working!
Discussion in 'Chevy C/K Truck Forum' started by ahobson1, Jun 20, 2010.
  1. ahobson1
    ahobson1 Member
    I have an 82 Silverado K10. Two nights ago my left tail light, turn signal and brake lights went out. Ok no big deal, I'll just replace the bulb...NOPE. Still not working. I had a replacement tail light I bought a while back in my garage just in case, wired it up, the reverse light and brake light will come on but very they're very dim.(Probably due to a weak connection since the splicers that came with the kit were total junk and i did it in a hurry) But still no tail lights! Can anyone PLEASE help me with this before I get pulled over!
  2. Chris Miller
    Check your ground wire.
  3. tbplus10
    Older Chevys have a habit of ground wire issues.
    Wouldnt be a bad time to check all the grounds and beef them up with replacement wires.
    Ground wires act like a sacraficial anode on a boat outdrive, they tend to corrode faster than the positive wire so they take a little maintenance from time to time.
  4. ahobson1
    ahobson1 Member
    Well I went out today, got the wires all crimped properly, replaced the grounds that needed it and cleaned up the rest of them. My turn signal, brake light, and reverse light are all shining brighter than they ever have. Still no tail light though! I'm completely confused, Any ideas?
  5. murdog94
    NOt to be dumb but have you put the new bulbs into the replacement tail light.
  6. ahobson1
    ahobson1 Member
    Well I used the bulb that came with the tail light kit. I'd never had to do this before so I didn't know much about it, might sound dumb but I thought it was kind of strange that there were only 2 bulbs, 1 for brake and tail and 1 for reverse. I don't understand why the brake light works but not the tail light. I guess I could try replacing the bulb again and see what happens. I'm running out of ideas.
  7. murdog94
    If it is blown on the tail light side then you have a bad ground that you need to find.. And if it isnt then you might want to trace the wire down the harness and see if it is cut or shorted etc.. Since the trail light and brake light actually run on the same wire on the trailer wiring harness i wonder if they are on the same wire for your tails??
  8. ahobson1
    ahobson1 Member
    I'll check it all out again tommorow. Running out of daylight here in Indiana. I really hope it is just a ground that I missed today. If not I have to pull off about a mile of electrical tape that the previous owner wrapped every wire with. Apparently nobody ever told him about conduit to protect wires haha. I'll keep you guys posted.
