'84 Engine Replacement
Discussion in 'GM Powertrain' started by flyinfish, Jun 11, 2010.
  1. flyinfish
    flyinfish New Member
    I have and '84 Chevy 3/4 ton with 350 and manual transmission. Living in California poses some issues with our draconian smog laws as I would like to replace the stock engine with a GM Performance crate engine. I don't want to get overly radical and am considering either the 290 HP or the 330 HP models. I can put all the smog equipment on it so it will pass the visual smog inspection but my concern is after all the $$$'s and effort, will it pass the sniffer test? Has anyone done this? Know of someone who has done this? Any and all input is appreciated.
  2. 2COR517
    You might consider swapping in a TBI system from an 87-91 gen truck/suburban. Or just bite the bullet and do a 5.3/6.0 swap with the full PCM.
  3. murdog94
    Good cats with a properly tuned carb, and good timing and the motor should pass with flying colors..
