84 k1500 no start
Discussion in 'General Chevy & GM Tech Questions' started by kbeve321, May 16, 2013.
  1. kbeve321
    kbeve321 New Member
    Hey everyone this is my first post here and im hoping you guys can help me out. I bought a 1984 gmc k1500 last summer which ran fine. I went away to school and it sat without being started so when i was finally home it would not turn over. I put the battery on a charger it would not hold a charge so i replaced the battery. I let me friend hook up the new battery which he did backwards. After this it would not crank, i checked the fuses all fine, i checked if battery voltage was getting to the starter it was so now the starter is currently jumped straight from the battery. The truck cranks now but will not fire. I checked fuel which it is getting i then grounded out a spark plug wire got nothing. I took the cap off the distributor and the rotor is turning so i checked how many volts was getting to the distributor. When cranking the volts drop to about 8, 8.5 so i jumped directly from the battery to the distributor still got the same voltage. What do you think the problem is would hooking the battery backwards go all the way back enough to screw up the ignition coil or the distributor or even fry the ecu. Is the ignition switch the problem any input would be appreciated.
  2. csltrains96
    csltrains96 Rockstar 100 Posts
    You probably fried the ecu and/or the ignition module. I would check on the ignition module first. electronics HATE to have their power supplies wired backwards.
  3. kbeve321
    kbeve321 New Member
    i know my friend got a beating for what he did but how do you check the ginition module and how would you know its the ecu.
  4. PhillipL
    PhillipL New Member
    If you have a DMM you can check the resistance of the ignition module, that would be the easiest way to check that..
