87' S-10 2.5 issue
Discussion in 'Chevy S10 Forum (GMC Sonoma)' started by GearHead899, Sep 19, 2013.
  1. GearHead899
    GearHead899 New Member
    sorry for my absence guys! turns out the issue was a bad ignition module. when i pulled the old one out i could see some corrosion on the prongs where the connector goes. ever since i replaced that it has been fine! WOOO! lol also we put on a new exhaust since it had none and was stupid loud. we just did a straight pipe off of the downpipe to a universal muffler we got online and did a side exit right behind the cab. still pretty loud but a ton better then what it was. My buddy also got bored and started rattle canning the exterior with primer (since it was about 10 different colors) so at least now its one color. will get some pics soon for you guys. Another question, my buddy wants to hook up a tack since there isnt one. how would we go about doing that on this truck?
  2. BurbanMan
    BurbanMan Member 1 Year 500 Posts
    The coil mounts to the top of the dizzy right? If so, you can get an accel tach install pigtail from the local autozone or oreillys to plug into it to make it all but plug and play
    Good to hear about the module
  3. GearHead899
    the coil actually mounts like under the intake manifold. not sure if that will work :confused:
  4. stchman
    IIRC, the 2.5L in the old S-10s was the "iron duke".
  5. BurbanMan
    Oh yeah. That's right. I'll do some homework and fin my wiring diagram for the 2.5 I used to have.
    Yes it is
  6. stchman
    It was amazing that GM put that engine into a LOT of vehicles, including a Camaro!!!!
    The Iron Duke was a very sturdy engine, but it almost sounded like a diesel it rattled so badly.
  7. Conlan Rose
    It actually is the engine in most USPS Mail Trucks because they are built on a modified S-10 frame. Most of those trucks are all still on the road after 25+ years of use.
  8. BurbanMan
    The green wire goes to te white wire coming off the ignition coil.
  9. GearHead899
    awesome! thanks man
  10. BurbanMan
    anytime. I try
