88' Z71 4wd stopped working
Discussion in 'Chevy C/K Truck Forum' started by Jagerballs, Dec 18, 2008.
  1. Jagerballs
    Jagerballs New Member
    Hi there, my 4wd quit working on me the other day, and I can't seem to pinpoint what I need to get fixed. I checked the actuator, which seemed to be working fine going in and out, until I tried to compress it by hand, and it was pretty easy to do. I thought this wasn't normal, so I went out and bought a new one, only to plug it in and find little to no difference between the two. Without installing and trying the new one, I put the old one back in after trying to manually engage the 4wd myself.
    Having the front end up on jackstands, I pushed in on the plate that the actuator engages, and i could spin either front wheel with no problem, while the other wheel would spin slowly in the opposite direction.
    Without having the plate engaged, each wheel would spin freely and independently.
    Does it sound like the pinion is stripped behind that plate that engages the 4wd?
    I'm pretty mechanically inclined, but I have very little experience with transmissions and 4wd systems.
    Is there anything else I can try? I'd hate to have to take it to a mechanic if it is something I can do myself.
    Thanks a lot!!!! Any comments or suggestions will be greatly appreciated!
  2. 04sierracrewcab
    bump .... anyone know?
  3. thatjerk01
    thatjerk01 Rockstar
    can u hear the transfer case try and change to 4x4?
  4. Jagerballs
    4x4 issue
    nope, doesn't make a sound...
  5. thatjerk01
    thatjerk01 Rockstar
    put all for tires in the air put the transmission in neutral the transfer case in 4x4 and spin the front axle and see what if the tires spin. the tranfer case takes a few thing as inputs to tell the transfer case to change in to 4x4. it could be the shift motor on the transfer case. it shifts it from 2 wheel to 4 wheel
  6. bigblue89GMC
    bigblue89GMC New Member
    One thing to check that happen to me is if one of your passenger side half shaft is sticking out of the axle a little. mine had a small washer that came out of place at the end of the axle shaft which wouldn't let the 4wd engage.
