89' Chevy Fuel Pump not working?
Discussion in 'Performance & Fuel' started by kuzco, Apr 12, 2012.
  1. kuzco
    kuzco New Member
    I bought a brand new fuel pump, fuel filter, fuel sending unit for this truck, I hooked up the wires and my meter tells me the fuel pump wires have power running through them when the truck is in "Run", however, the fuel pump isn't starting up, what's wrong with it? Thanks.
  2. osgprometheus
    osgprometheus Rockstar 100 Posts
    Where did you get the pump? Did you bench test the pump? Is your fuel pump relay engaging?
  3. kuzco
    kuzco New Member
    I got the fuel pump from oreilly, I did not bench test it, and, I'm not sure if the fuel pump relay is engaging, I pulled it off and am going to replace it just to find out if it's the reason.
    Thanks.
  4. kuzco
    kuzco New Member
    The fuel pump relay was good, it had no problems.
  5. 07XCSB
    07XCSB Active Member 2 Years 1000 Posts
    Sounds like you either got a dead pump or bad ground.
    I've been getting alot of new bad parts from Oriely's lately.
  6. osgprometheus
    Ok. A lot of the time you get a wiring harness with the new pump. I agree with the checking the ground next. If nothing still, take the pump back.
  7. kuzco
    kuzco New Member
    Thanks got it going, the ground was bad on it.
  8. osgprometheus
    Cool Cool. Glad it is working now.
