89 shortbed 305 tbi... no start
Discussion in 'Chevy C/K Truck Forum' started by timhall1787, Oct 1, 2011.
  1. timhall1787
    timhall1787 New Member
    is there a crank sensor on this truck? what is the sensor by the starter?
  2. chevyracingss
    chevyracingss New Member
    Assuming it is the original engine, no there is no crank sensor.
  3. Revredneck
    Revredneck Rockstar 100 Posts
    The function of crank sensor is accomplished by the pickup and module in the distributor. Does it have spark? Take a good hard look at your distributor cap and rotor, also, check your fuel pump pressure. It should be between 9 and 13 psi, the higher the better.
    That sensor down by the starter is the knock sensor. It will not cause a no-start on that engine.
    Good Luck and God Bless
