'89 Silverado radio panel blank?
Discussion in 'Audio, Video & Gadget Tech' started by csltrains96, May 9, 2012.
  1. csltrains96
    csltrains96 Rockstar 100 Posts
    I own an '89 Silverado K2500 with the factory digital AM/FM radio right up next to the gauge cluster. I already know that there aren't any aftermarket radios that will fit in this spot.
    My question is, though, did GM ever make a blank panel for this spot for fleet vehicles or W/T trucks that were ordered without a radio installed? And if they did, what is the part number? Can I still order one? I'd like to install a Secret Audio system, but I would need a blank surface to mount the system controls to.
    Thanks in advance.
  2. Enkeiavalanche
    Enkeiavalanche Loving the Outdoors Staff Member 4 Years ROTM Winner 5000 Posts
    I think you can get a Pocket for in there.. Other then that A blank ABS plastic Pc will fit and give you room to fit anything..
  3. kw70chevy
    kw70chevy Member
    i had a 90 model the same way i just left mine in i bought a radio plate and put it where the casset deck was under the two vents.i sill got the plate in the barn someware in a box.
  4. ChevyFan
    Thread moved. This is not a customer service issue, moved to the proper forum.
  5. Strino78
    Strino78 Member
    Tons of aftermarket available for it -- $12 with shipping included is all you should spend.
    EBay "K1500 Pocket" and you'll find a fair bit of them. I went this route myself when I removed my radio. This is the seller/part I used.
    http://www.ebay.com/itm/GM-GMC-CHEVY-PICKUP-TRUCK-POCKET-RADIO-DASH-KIT-CAR-STEREO-STORAGE-BIN-CUBBY-/280774487238?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AK1500&hash=item415f76acc6&vxp=mtr#vi-ilComp
    *There's a tiny amp stuffed under the dash for the radio too. It isn't hard to remove but it is jammed in there on the right side of the ash tray. I left mine in there for the time being -- with wires disconnected and tucked away.*
  6. csltrains96
    Thanks for all the info!! I'll be checking out the pocket.
