89 TBI 454 won't idle
Discussion in 'General Chevy & GM Tech Questions' started by lucaslaw, Jun 20, 2009.
  1. lucaslaw
    lucaslaw New Member
    3500 truck, 207000 miles, supposed to have been rebuilt.
    I replaced plug wires, plugs, unhooked "brown wire" connector under glovebox and held throttle with a clamp (to keep it running) to adjust timing to "0", plugged brown wire back up, still won't idle.
    Cleaned IAC, checked vacuum hoses, there is a device about the size of a half pack cigarettes with a plug and wires on one end and a vac hose attached to intake on other,its loose under air cleaner, is this the MAP sensor? Could this be the problem? Cound the TBI need rebuild? Spray pattrern looks good.
    Now the check engine light is on, I don't have a OBD 1 scanner, is there a jumper/count flashes method to determine the code?
  2. Jimmiee
    You need to jump the ALDL at pins B and A.
  3. lucaslaw
    lucaslaw New Member
    No code, followed procedure to reset IAC. Got it to idle at 450rpm, shut it down, plugged IAC back in, now it won't idle and will barely start.
