90 Chevy C1500, No fuel @ injectors
Discussion in 'General Chevy & GM Tech Questions' started by Grimm, Aug 19, 2012.
  1. Grimm
    Grimm New Member
    I recently had my 90 Chevy C1500 broke into recently and steering column was destroyed, but had it rebuilt.. After I re-installed column and went to start all i got was crank but no start...Just to be clear truck was running fine before it was broke into.. I realized no fuel was making it to injectors; however, i am getting spark, ignition module tested good, pick up coil tested good, can hear fuel pump cycle.. got no light on fuel injector test though.. Have gone through everything I can think of.. Any insight or advice would be greatly appreciated!!
  2. RayVoy
    Well, if the only thing damaged was the column, the problem has to be electric.
    My guess was the fuel pump relay, but you say you can hear the pump run.
    Hmmmm, if pump is running you should get fuel to the rail.
    Are you sure it is the fuel pump and not something else, like maybe the rear suspension air compressor (if you have one)?
  3. Grimm
    Grimm New Member
    No air ride.. I just dismissed the fuel pump relay because i could hear the pump running.. anything is worth a shot at this point though.. Also, after cranking the injectors are wet, but there is no spray.. Just isnt making sense..
  4. Conlan Rose
    There may be a clog in the fuel system if the injectors are getting some fuel.
  5. Grimm
    Grimm New Member
    Any ideas on where to start on looking for a clog short of taking the TB apart/rebuild?? Fuel pressure is good from pump..
  6. Conlan Rose
    well check the fuel filter and follow it up in to the evap and to the throttle body check pressures and use some thing like a thin wire to poke down the line to feel for any clogs.
  7. RayVoy
    Ok, if they are wet, I'd check the pressure at the rail, maybe the "open" sig is not being sent to the injectors
