1. Chevy Truck Forum
    Welcome To GMTruckClub.com!
    Online since 2004, we're the #1 Chevy Truck & SUV user community. If you have any questions about your Chevy or GMC Truck, SUV or Crossover, or just want to connect with other GM owners and enthusiasts around the world, you've found the best place on the internet to do that.
    Join Today ~ It's Free
    Registering is Free and Easy! Do it today and we'll see you on the forums soon!
'90 Suburban a/c air vents & switch question..?
Discussion in 'General Chevy & GM Tech Questions' started by omnisi, May 17, 2009.
  1. omnisi
    omnisi Rockstar 100 Posts
    I just got the a/c on our '90 Sub repaired (compressor and all) and I noticed that when the a/c switch is in the "Normal" position, that the air flow still comes out as if the switch were on "Bi-level"....about 50/50.
    Where do I need to start, or what do I need to do to get all/most of the air to come out of the dash vents when the switch is on "normal" ?
    Thanks
    BTW - Defrost works fine as does the "max"...
  2. vncj96
    If I could see i pic of the vent controller it would help, just cant picture its setup, I know its the two sliding levers though
  3. omnisi
    Yes, its the slide levers with the pattern:
    max - normal - bi level - vent - heat - defrost ...in that order, and the "normal" position is acting like the "bi level".
  4. vncj96
    Your bi-level setting I am guessing isnt for the air, just cool or heat and your normal and max setting is specifically for ac, so this is by design, max is full ac.
  5. omnisi
    According to the controller, the a/c incorporates the "max-normal-bi level", then "Vent-heat" together, the "defrost" separate. So, the bi-level is part of the a/c control.
    Thoughts?
    Thanks for the help!
  6. vncj96
    My 85 chev truck only had normal and max for he ac so i am guessing one of the blend doors is not moving correctly
