91 K-1500 Severe vibration in 4WD system
Discussion in 'GM Powertrain' started by Hairstraightback, Nov 12, 2012.
  1. Hairstraightback
    Hairstraightback New Member
    I have 1991 chevy k1500 pick up and i replaced the front U-joint at the front diff and put a 4WD actuator eliminator in and got a severe vibration at about 60km/ph in 2High, would it be possible my front and read drive shafts are out of phase? Also replaced my transfer case with one from a wrecker about 6 months ago (it had 90 days warranty) but never had 4WD i just figured it was the actuator, if i put it in 4High with the original actuator still had vibration, with the eliminator it does it even in 2High. Where would the vibration more likely be coming from the transfer case, the drive shaft, the front diff or possibly c-v joints or hub? Also noticed a leak at my passenger side c-v joint, I read somewhere else that In 2High with the thermal actuator in the front passenger side spins free, is there anyway to test it?
