92 gmc sputtering
Discussion in 'General Chevy & GM Tech Questions' started by redneckGMC, Aug 2, 2013.
  1. redneckGMC
    redneckGMC New Member
    I have a 92 gmc k1500. When i start it it idels bout 1000 rpm ans when i put it in gear the idle drops to bout 400 rpm and it starts to shake. When im driving it runs ok but going up a hill it starts to shake real bad. I pulled the plugs and i will be replacing them. Im confused on what the problem might be.
  2. donyms
    Welcome to the club, it's great to have you aboard. More than likely the plugs will help but I would replace the wires too and then see how it does. I only use AC delco plugs and wires. They just seem to work best. :glasses:
  3. redneckGMC
    Ok i have been reading on what else could be wrong and other people have said an iac valve, tps sensor, map sensor . Im going to do a full tune up later today and hopefully it fixes the issue. My truck has no trouble codes.
  4. redneckGMC
    Just changed the plugs and that fixed the issue.
  5. RSM2
    RSM2 New Member
    I always use AC Delco parts when doing a tune-up. All that aftermarket crap never seems to last as long.
  6. mfleetwood
    Welcome to the Club!!
    I moved your thread to the correct section of our Forum....Glad you found the answer to your problem!
