92 sierra low beams do not work high beams do??
Discussion in 'General Chevy & GM Tech Questions' started by id10t, Dec 31, 2010.
  1. id10t
    id10t New Member
    Hi i have a 1992 stepside z71 4x4 with 350, just got the truck its old and a little beat up and started fixing things, now Im down to the headlights and the low beams dont work, but the high beams do. i checked the bulbs first with an ohm meter and then hooked up 12v and they work out of the truck, so its not the bulb. today i bought a new headlight switch and changed it out, still no low beams. im looking for a wiring diagram or someone to tell me where there is either the relay for the low beams or a fuse or what ever ideas you may have.
    thanks for any sugestions you can give.....
  2. Thundare
    Thundare Rockstar 100 Posts
    Your probly missing a ground somewhere, Check to see if your getting power when on low and if you are its the ground.
