92 Suburban K2500 Front Drive Shaft U-Joint Removal?
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by corvetteman, Sep 8, 2012.
  1. corvetteman
    corvetteman Member
    Does any know how the U-Joint caps are held in the yoke on the front drive shaft?
    I’m unable to see a clip of any kind on the inside or outside of the yoke in fact the caps are flush with the outside of the yoke.
    The only clips I can see are on the other two caps.
  2. 84fiero123
    84fiero123 Epic Member 5+ Years 1000 Posts Platinum Contributor
    check inside the caps inside the yolk
  3. corvetteman
    corvetteman Member
    Unable to see any clips or snap rings inside or out on the two caps in the yoke.
  4. bazar01
    bazar01 Rockstar 100 Posts
    Maybe the two caps in the yoke are staked in multiple locations. If you look at the outside of the cap and yoke, do you see any crimped sections?
  5. Pikey
    I looked at 4 different sites and they all show the replacement as having (4) inside clips. So, I would have to assume that yours has clips inside the yoke also. Sometimes they are really hard to see with all the grease and dirt in there. Feel around in there with a small flathead screw driver and see if you can feel the lip of them. If they are the original u joints there may not be clips. They are held in with a molded plastic. This requires you to heat the joint to the point that the plastic shoots out of the little holes on the ears of the yoke. Fast forward this video to about 2:20 for an explanation
    http://www.youtube.com/watch?v=073tYBBRQqA
  6. corvetteman
    corvetteman Member
    Thanks for the vidio Pikey. I was wondering what those dimples were for. I saw them and couldn't figure out what they were for. Must be original u-joints. Twenty year old u-joints…WOW!!! Got a lot out of them.
  7. Pikey
    You can't complain about that! 20 years. How many miles?
  8. corvetteman
    corvetteman Member
    178,000 and doesn’t burn a drop of oil!
  9. pbrackett
    pbrackett New Member
    You da man Pikey! thanks for the post - those little knobbies were puzzling me also.
