    Join Today ~ It's Free
93 K1500 Temp. Guage Reading Cold
Discussion in 'Chevy C/K Truck Forum' started by DanPruski, Jan 18, 2012.
  1. DanPruski
    DanPruski Member
    1993 K1500 4.3L V6,
    i changed out the thermostat a number of times, flushed the coolant, and changed the temperature sending unit recently to try to get the guage to read normal around 190, but for some reason it is always reading cold around 140 and doesnt put out the hottest air. Im lost on what to check next. 5 thermostats ive tried and they all have been doing this, and its a brand new sending unit, with new 50/50 coolant since im in alaska.
    Any help?
  2. 86G20
    86G20 New Member
    This new a truck has a clutched fan on it. Is there a chance the fan clutch has siezed up on you and is moving too much air even when the vehicle should be in "warm-up" mode. Does the temp guage correspond to one stuck in the radiator top? Just wondering if it is somehow out of calibration. Are your other gauges seemingly reading correctly? Some rigs (not sure about later GM) used a step-down transformer to run gauges on say 4 volts instead of 12v. It would affect all gauges equally if that were the case. In Alaska do folks put those zippered covers on the front of the grille during winter. I always ran a piece of cardboard between my radiator and the grille on my little 4-cylinder car to get more/quicker heat in the winter time, but it ran an electric fan. Otherwise my carb with after-market air filter would "ice-up" even in Northern CA.
    I hope it is something simple. I've heard of people who swear by various brands of T-stats and condem others as junk!
    Good luck, Chris
  3. DanPruski
    DanPruski Member
    negative, my 93 doesnt have a clutched fan, it just runs with serp. belt. and the radiator cap doesnt have any tye of guage on it, its just a pressure cap. Other guages seem normal.
    and yeah i throw a piece of cardboard between the radiator and core support to block most of the cold air from coming into it.
    yeah ive tried the Fail-Safe tstats and they didnt change anything so went back to the OEM replacement Murray ones.
  4. 86G20
    86G20 New Member
    I looked up the 4.3L V-6 in a K1500 and the stock fan clutch is AC Delco Part #154552. My 1996 van with serpentine belt has a clutched fan, it is just another type of thermostat that lets the fan blades more-or-less freewheel until it reaches higher temperatures. You should be able to tell whether it is functioning by just trying to turn the fan blades on a cold engine by hand. The viscous nature of the clutch should let it turn without moving the belt.
    Never heard of Murray T-stats; always figured stock GM was AC Delco. The idea with the rad cap is to remove it and run the engine up to "normal" operating temperature with a kitchen thermometer immersed in the coolant. That way you can compare what is circulating through the radiator with what the gauge is telling you.
  5. DanPruski
    DanPruski Member
    ohh weird, ive never heard of it or noticed it having a clutched fan. so just reach down and turn it by hand without moving the belt? so basically your saying the fan might be turning with the belt all the time and it shouldnt?
    The Murray ones is just what O'rielly sells as their standard coolant stuff. Anyone i talk to never has problems with that brand, they sell OEM replacement and Racing equiptment for cooling systems.
    and okay, ill try that tonight with checking the coolant temp in the radiator.
  6. 86G20
    86G20 New Member
    Yup, that's right on turning the fan blades without the pulley moving against the serpentine belt. Another good check is to see whether the center of the radiator stays cooler than the top/bottom/sides (depends on where the "tanks" are located. If the center stays cooler it is a sign your core is plugged; with a plugged core your coolant could be "short circuiting" and never really circulating through the entire engine to pick up that heat you are looking for. Basically you want a uniform temperature more/less across the core. An infrared gun-type thermometer is good for checking this, but it can be done by touch. I assume you have the process of bleeding air from the system down to a science, having done 5 different T-stat changes.
    BTW- how many miles are on this rig and when was the last water pump installed. I've heard horror stories of the impeller vanes getting eaten away by corrosive water/antifreeze and the darn thing just spins around without pushing the coolant where it needs to go. Typically the opposite of what you are describing results - overheating.
    Chris
  7. DanPruski
    DanPruski Member
    okay, yeah ill check that out. And do you mean the heater core? im gonna try flushing it tonight as well, just pull the hoses and put the garden hose in it.
    The truck has 281K, enging had about 80K, i havent changed the water pump on this engine yet i dont think. Yeah bleeding air is definately down to a science.
