93 suburban head ache
Discussion in 'Chevy Suburban Forum (GMC Yukon XL)' started by wobble-dude, Jun 19, 2012.
  1. wobble-dude
    wobble-dude New Member
    i have a 93 suburban7.4l 4x4 popping when accelerating. i have chenged distributor,plugs , wires , cap , rotor, and fuel pump . any ideas on what could be the problem ? truck starts and idles fine
  2. RayVoy
    Hard to tell from your description, but it sounds like spark knock.
    Try some high test gas.
    If it goes away, the combustion chambers need to be cleaned.
  3. Naptime
    Naptime Rockstar 100 Posts
    What he said.
  4. RallySTX
    RallySTX Member 100 Posts
    Popping under the hood, or out the exhaust? Does it miss while popping, or run fine but pop anyway? Does the smell of raw gas follow you arround? What does your tail pipe look like?Are you sure there are no restrictions in the air intake or exhaust? Is everything under the hood still hooked up? Sounds like the timing is way off. Has it lost any power or does it loose power when this happens?
    Brian L.
  5. janikphoto
    janikphoto Rockstar 3 Years 100 Posts
    Mine was popping under the hood. Turned out that my injectors needed some real TLC. I would suggest a professional injector service, or something more aggressive than just the in-tank stuff. It cured my problem, which sounds very similar to yours...
  6. wobble-dude
    The popping is under the hood . Today i had the throttle body and injectors rebuilt . checked timming and filled up with 92 octane fuel. Still popping
  7. RallySTX
    Have you reverified the fuel pressure? Check and clean all ground wires, look for vacume leaks, and give it a compreession check.
    Brian L.
