94 Blazer Fullsize - Rear Shock Mount Idea
Discussion in 'General Chevy & GM Tech Questions' started by DoubleTap308, Nov 13, 2009.
  1. DoubleTap308
    DoubleTap308 New Member
    I have a 94 Fullsize Blazer and here's my problem:
    The upper rear shock mounts are pretty rusted, to the point that I can't get the bolts out. Eventually I'll get them out but the mount will be shot.
    Here's what I was thinking for a solution:
    I can cut off the old shock mount and run a different setup. I was thinking along the lines of the 84 Suburban I have which is just a bolt through the shock eyelet and then into the frame. After I tighten it down I can tack weld it in place. I will probably have to use some spacers to get the right spacing off the frame
    Anyone have any kind of input on this idea.... good, bad, other solutions? :neutral:
  2. DoubleTap308
    BTT Anyone still around on these forums?
  3. thrasher
    thrasher Rockstar 100 Posts
    A few pics would be helpful, but can you get to the area with a cut off wheel? Might be easier to just cut the bolt heads or whatever is holding it in & then pop the bolts out with a drift.
